[SOLVED] Ryzen 2200G + RX 570. BSOD issue
Vishal_7
138
Got a 2200g in 2020 as a starting build . R5 3600 gets released and bought RX 570 along with it. Swapped 2200G with 3600 +570. Never used 2200G+570 combo.
Tried today after 1.5yr just to see difference in games and started getting BSOD within 20 seconds of system start.BSOD continues.
Getting repeated Errors in Event Viewer:
  1. Audit events have been dropped by the transport. 0
  2. The previous system shutdown at 5:43:24 PM on ‎6/‎6/‎2021 was unexpected.
  3. Crash dump initialization failed!
  4. system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
  5. Audit events have been dropped by the transport. 0----- (from here the same above 4 repeart)
Since I couldn't use the system hence just disconnected the 8pin power connector to the RX 570. Voila, system is working perfectly fine. No issues.The GPU is still there in the mobo but without the 8pin.
Other specs:
b450m pro vdh, 16gb CL16 ,,3000Mhz . CX450 PSU..[these same specs power 3600+570 combo and work without any issue in any games whatsoever], all softwares up to date. windows up to date.
What is happeing if someonecould point out please ? If someone had same issues or something ?
Thanks.
How old is the PSU in your build? What BIOS version are you currently on for your motherboard? You're severely underpowered for the build with that 450W unit, in fact you should be in possession of a 550W reliably built PSU.
1.5year old psu. BIOS Ver: 7A38vMD ; never had any issue with power related in this build tbh.
