I'm new to ryzen and overclocking, there are a few things that have me confused.
First thing first, the motherboard I'm using is the MSI B450 Tomahawk MAX on the latest bios (v34).
Now, down to the actual concerns.
I want to overclock my ryzen 2600 to just get the most out of it. I bought it used and the guy I bought it from told me he was able to get 4.2ghz but the voltage was a little too high for my taste, but it is possible.
I did take a shot and try to OC, I just went with a basic 4ghz clock and override 1.325v. This was just a first try and I just wanted to see if it did anything. First thing I noticed was that the clock speed doesnt downclock at idle, at all. Also the voltage doesnt go below the manual override I set, which idk is safe not or not. Will this degrade my cpu fast?
When I manually set the core speed, AMD cool n quiet disabled itself. Is this how its suppose to work?
Are there settings that I'm suppose to enable or configure to make the core downclock and voltage also drop when idle?
I tried manually enabling Cool n Quiet but then it asked which state, 0,1 or 2. This just confused me more. Can someone please explain this all to me? Is it ok for the core to stay at max speed and max voltage all the time even at idle?
