[SOLVED] [Ryzen 5 5600X] Upgrading PC - Need compatibility review and recommendations to improve my selected components
BrainY
392
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (Purchased For $325.00)
CPU Cooler: Noctua NH-D14 64.95 CFM CPU Cooler (Purchased For $0.00)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard ($108.99 @ Amazon)
Memory: *G.Skill Flare X Series 16 GB (2 x 8 GB) DDR4-3200 CL14 Memory ($114.99 @ Newegg)
Storage: OCZ TRION 150 960 GB 2.5" Solid State Drive (Purchased For $0.00)
Video Card: Asus GeForce GTX 1070 8 GB Video Card (Purchased For $0.00)
Case: Fractal Design Define R4 ATX Mid Tower Case (Purchased For $0.00)
Power Supply: SeaSonic FOCUS Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply ($103.99 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit (Purchased For $0.00)
Monitor: Asus MG248Q 24.0" 1920x1080 144 Hz Monitor (Purchased For $0.00)
Total: $652.97
  1. Already ordered an AM4 bracket for the Noctua NH-D14
  2. I don't know if my ram will fit underneath my Noctua NH-D14 heatsinks as their website doesn't tell.
  3. I used LinusTech's PSU tier and this PSU was considered A-Grade.
  4. I don't care about cosmetics
  5. I don't care if it's a B550 or X570 as I won't run SLI or probably majorly overclock.
Anything else you would consider changing?
Total: $652.97
The psu,Seasonic updated focus series it's now called Focus gx and gm(the 2020 model of the focus you wanted to buy).Also the ram you can't get a g.skill rgb neo 3600 cl 16 for 130$ if you are interested.Other that looks really good.
Gm(120$)https://www.amazon.com/Seasonic-Sem...words=seasonic+focus+gx&qid=1612290748&sr=8-2
Gx (130)https://www.amazon.com/Seasonic-GX-...words=seasonic+focus+gx&qid=1612290748&sr=8-1
What's hte difference between them? Semi vs Full Modular?
The cables,Semi modular has both the 24 pin and the 8pin connectors attached to it (Other than the 24 pin and 8 pin all the cables are detachable)
Modular has no cable attached to it so you can use the cables you want and throw the rest in the box (all cables are detachable)
So it's more like a better cable mangement
I personally have the gx
Ended ordering the below
Memory: G.SKILL TridentZ Series 32GB (2 x 16GB) DDR4 3200 (F4-3200C16D-32GTZKW)
Power Supply: Seasonic FOCUS GM-750, 750W 80+ Gold, Semi-Modular
Solid
