Question Ryzen 7 2700x/3700x Supported by A320m-a pro max mobo?
Sep 27, 2021
Hi yall,
Just wanted to ask if an MSI mobo can support the Ryzen 7 2700x/3700x, also if so which version of BIOS will i require at the least?
Thanks.
Friesiansam
103
43
10,620
Hi yall,
Thanks.
The best thing to do is to check MSI's CPU support list, for your motherboard, on their own website. Also, nobody can tell you anything if you don't mention the exact model of the motherboard.
Hi yall,
Thanks.
both are supported by default since MAX series from msi have native support for 3000 series. recommended? i don't think so. i prefer use a good B450 motherboard for those cpus since they take alot of power and could make the vrm hot enough.
