Safely remove hardward does not work with external drive
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
When I try to "safely remove" my external hard drive I get a error message
that reads "the device cannot be stopped right now. Try back a little later."
In "device manager" the radio button is check for "optimized for performance".
This is not a new problem. It has never worked with my external hard drive.
the drive is a deskstar 160gig from hitachi. When I bought it from compusa
they had pkg it with an external case. I'm not sure if that has anything to
do with it or not.
I'm running xp pro.
I hope someone can help.
Hi,
On a side note, you will want to make sure System Restore is NOT set to monitor the
external drive.
Keeping System Restore Healthy
http://bertk.mvps.org/html/healthy.html
Regards,
Bert Kinney MS-MVP Shell/User
> get a error message that reads "the device cannot be
> bought it from compusa they had pkg it with an external
> case. I'm not sure if that has anything to do with it or
> not.
> I'm running xp pro.
