Question SATA hard disks not detected after MoBo upgrade
LrsLex
57
Hi y'all!
I updated my mobo from Asus B350 Prime Plus to Asus TUF Gaming B550 Plus and since neither of my SATA disks are detected by BIOS or Windows.
I have enabled CSM as many guides.. well, guide and every SATA port (?) individually in the BIOS. Tried a different power cable as a long shot. Haven't tried different SATA cables, because what are the odds that both cables fail at the same time.
The disks are EVO 850 500 GB and an ancient 1 TB 5200 rpm HDD.
Should it matter in which SATA ports the cables are plugged? I just plugged them to the easiest ones available because I already had my GPU in and was feeling lazy.
Thanks for the help!
It's the bottom slot then. In such case slots marked as SATA5 and SATA6 are disabled. You have to use the remaining four slots.
... And of course the disks were in slots 5 & 6 since they were the only ones reachable under the colossal 6900 XT. 😀
Removed the card, reslotted to 1 & 2 and the drives were found.
Thanks all!
Reactions: DRagor
