[SOLVED] Second monitor restarts 3 times when powering up PC
cazetoG
41
Hi.
So I don't know if this is a problem, as my second monitor works fine BUT
whenever I switch outputs on my second monitor to HDMI and back to DVI(or power up the PC), both my monitors goes black for a couple of seconds and then come back on in total of 3 times, before everything is settled.
It just annoys me, since I have to sit and wait for my monitors to settle in.
Is this a normal thing, having 2 monitors?
GTX 3080
2 x Asus 1280p 24" G-Sync monitors
Hi.
GTX 3080
Yes it's normal it's the displays adapting to the res of dual display
Hi.
GTX 3080
