Hey everyone!
This problem has been going on for some time now and it's starting to give me a headache. I have an Asus 1600x900 main monitor, which is attached by a DVI cable into the GPU, as well as an NEC P462 large screen display. I've had this setup for over two years and at one point I disconnected the NEC P462 to attach my Macbook Pro via an HDMI cord (using the cord originally plugged into the PC's GPU). I attached the cable back into the GPU and monitor after finishing with the Macbook and the resolution of the NEC P462 monitor is now stuck at640x480 resolution, and all other resolution settings are grayed out in Windows 10 display settings. Here is what I've tried doing so far:
Here are the specs of my computer (pulled from AMD problem support wizard): https://pastebin.com/yNpUrZ7F
- Tried switching to a new HDMI cable
- Tried using different HDMI inputs on each device
- Updated GPU drivers (clean install)
- Updated NEC P462 monitor drivers
- Updated to the newest version of Windows 10
- Looked for any scaling options in my GPU's settings, didn't find any
