I got parts to build my first computer and am stuck with my case and motherboard. I put it all together and the motherboard starts up fine, gpu lights up, led ram lights up, cpu fan is running, everything seems okay but I have a power cable on my case which is connected to my case LED's, fans, etc. I can not find a power source on my motherboard to plug my case power pins into, and therefore I am left with fans that don't run and led's and ports that don't work. I have tried seemingly everything and can't figure it out. I am using a MSI B450 Motherboard with a Rainbow V2 case if that helps at all. If you need more information just ask me and thank you in advance.
