[SOLVED] Shouldn't my pc build be able to run anything on max settings 4k resolution and get over 60fps???
Jan 23, 2019
5
This is what i've got going on in my rig. Shouldn't I be getting crazy good fps at 4k?
Windows 10 Home 64-bit
CPU
Intel Core i7 @ 3.70GHz 28 °C
Coffee Lake 14nm Technology
RAM
32.0GB Dual-Channel Unknown (16-16-16-39)
Motherboard
ASUSTeK COMPUTER INC. ROG STRIX Z370-E GAMING (LGA1151) 24 °C
Graphics
LG TV (3840x2160@60Hz)
3071MB NVIDIA GeForce RTX 2080 Ti (NVIDIA) 31 °C
Storage
1863GB TOSHIBA DT01ACA200 (SATA ) 29 °C
931GB Samsung SSD 970 EVO 1TB (Unknown (SSD))
Optical Drives
No optical disk drives detected
Audio
NVIDIA High Definition Audio
Power Supply
Corsair 750 watt
The fps counter shows 'theoretical' fps.
The monitor's max refresh(hz), is just that. It can't display more than that at any given time.
So if the cpu/gpu are churning out 100fps at 4k according to the fps counter, but your monitor's max is 60, what you're really seeing is 60fps. In order to actually see more, a monitor that can actually deliver that framerate is needed.
I can't help but be skeptical when some folks post about getting 200-300fps in a game like CS;GO, R6 Siege, etc., but don't actually have a 240hz monitor. -__-'
But to actually answer your question: yes, it'll run about anything, unless it's...
With the latest GPU the drivers and the game are important. You’re trying to play titles like Metro Exodus yes that card is required. You could have saved money and got Nvidia GeForce RTX 2070. Always buying over priced GPUs will not always be a balance between power and performance.
But to actually answer your question: yes, it'll run about anything, unless it's badly designed one, like PUBG. You'll have no trouble sustaining 60fps. Going over that is another matter as I described above.
Awesome! Good to know! 60fps at 4k max settings is good enough for me at this time as I would LIKE to buy a more powerful display, but I'm going to have to settle for what I have because of my recent pc component purchases. Thanks for making that clear for me! It makes total sense! I'm using a 750 watt power supply. The recommended for this graphics card is 650 watts. So I think I should be good on that end. The performance has been great. Basically I just bought a really expensive gpu and I'm being a total worry wort about it.
Most older games it's no problem. But for some reason I feel like my system isn't as powerful as I figured it should be with the i7-8700k and the RTX 2080 ti. Any comments or suggestions would help. Should I get better ram? Should I upgrade my processor? I thought with these components I would have a powerhouse gaming pc that would be able to handle anything with max settings 4k 60fps. Some of the newest AAA titles I can't get that at all.
Operating System
CPU
Intel Core i7 @ 3.70GHz 29 °C
RAM
32.0GB Dual-Channel Corsair @ 1200MHz (16-16-16-39)
Motherboard
Graphics
3071MB NVIDIA GeForce RTX 2080 Ti (NVIDIA) 37 °C
Storage
1863GB TOSHIBA DT01ACA200 (SATA ) 26 °C
Optical Drives
Audio
Power Supply
Corsair 850 watt Platinum rated
Yeah I have the RTX 2080 ti founder's edition. an i7-8700k 32 gbs of 2400 ram. I love the graphics card. My pc is powerful, but it's like on the new game Anthem, it doesn't run well at 4k. I know my pc is built correctly and it is very powerful. I've been told some games just aren't optimized very well. Maybe that's the case? I can run Anthem at 4k but not at max settings. Kind of upsetting.
