Hello, so recently i noticed some weird texture bugs and so on. I have this in every game. Some objects disappear and pop up randomly.
View: https://www.youtube.com/watch?v=Lpj2GtvdoHg
My apologies.is this a question?
full system spec?
I actually reinstalled the pc today. So the ssd is almost completely fresh beside the games i've installed. The ram is 16gb. The power supply is 2 months old, same as the gpu. However returned the gpu, took 3 weeks to get it back due to repair.how full is the ssd?
what the ram?
brand and model of the psu?
That's super weird. I'm using up max 8gb of vram? Especially in rdr2 and other games.my guess is that youre running out of RAM and VRAM, hwinfo shows 25-30GB virtual RAM being commited, that is more than your 16GB RAM...which can swap a little, VRAM is maxed aswell
16gb vram is used on your videoThat's super weird. I'm using up max 8gb of vram? Especially in rdr2 and other games.
Sorry, but i don't really get it. How am i using 19gb vram on wow? Sorry a bit confused. Why is this?16gb vram is used on your video
look in eventviewer if you have any app which reports radar-preleakHowever, the same issue persists after changing the resolution and graphics... ETC. I found out that i have the same problem with my older graphics card. But i remember that this issue came when changing the cpu cooler now.
hard to see stuttering on 400fps game with 30fps videoThe stuttering happened after changing the cpu cooler. I don't remember having problems with view distance. x)
that is error reported by amd driver which mirosoft doesnt know how to interpret it
Hello! My thought aswell. Wow is too old to be maxing out on vram. I know more about parts in general but when it comes to what stuff do and so on i just get lost. Atleast when it comes to side stuff. Like vram and power limits etc. I'm more capable of stuff like what motherboard does, cpu... Etc.I'm honestly at a loss as to why a game like WoW would be able to max out an RX 6800 XT. There has to be a bug in the game because if an RX 6800 XT is running out of VRAM, then every card that isn't an RTX 3090/Ti, RX 7900 XT(X) or RTX 4090 should also be running out of VRAM.
I'm sorry that I don't have any ideas for you but I did want to say that you have a really cool name. 👍
I might have to do a DDU removal on both nvidia and amd drivers tomorrow, again.that is error reported by amd driver which mirosoft doesnt know how to interpret it
Check my post again. Right after I did it, two ideas popped into my head and I edited it. They might be useless, but you never know...Hello! My thought aswell. Wow is too old to be maxing out on vram. I know more about parts in general but when it comes to what stuff do and so on i just get lost. Atleast when it comes to side stuff. Like vram and power limits etc. I'm more capable of stuff like what motherboard does, cpu... Etc.
DDU is good ideaCheck my post again. Right after I did it, two ideas popped into my head and I edited it. They might be useless, but you never know...
I have already reinstalled wow. + reinstall the whole pc today. The issue persists sadly. I just did a ddu removal on both nvidia and amd now. So currently installing the drivers for my rx 6800xt. However the amd settings are on default. Beside the undervolting.I'm honestly at a loss as to why a game like WoW would be able to max out an RX 6800 XT. There has to be a bug in the game because if an RX 6800 XT is running out of VRAM, then every card that isn't an RTX 3090/Ti, RX 7900 XT(X) or RTX 4090 should also be running out of VRAM. I also think that it's a bug in the game because from what I'm seeing, it keeps allocating huge chunks of VRAM even when you drop the resolution (which shouldn't happen, ever).
I would try two things:
1.) Re-install WoW
2.) Look in Adrenalin to see if there's a setting that affects VRAM usage. I'm at work right now and so I can't check it myself but it might be worth a look.
I'm sorry that I don't have any solid ideas for you but I did want to say that you have a really cool name. 👍
