Question Sound problem
bulatla96
31
Every time I turn my PC on I don't have sound. So I have to go to device manager and uninstall sound drivers. But I have to do the process 2 or 3 times ( don't know why). After that, I get my sound back. The problem is only for my speakers. When I use a headset it works fine. Any ideas? Thanks in advance.
Most likely thing I can think of is the internal audio device isn't getting set as the default output device in the Sounds tab of the control panel. Your headset I assume is USB, and when connected it becomes the default device.
That was the first thing I checked. Speakers are set as the default. I don't have my USB headset pugged in.
H310CM-DVS
Try the audio driver on this page for your motherboard:
Unfortunately nothing.
