Problem:: The problem is that every time I run something remotely 3d or do anything that requires video, a hissing sound or some sort of sound anomaly is put out from my speakers. On Lattice(a OpenGL 3d screensaver on reallyslick.com) it's more of a squealing sound, however. When I scroll down up and down pages it makes a short and quiet zzz type of noise as it's scrolling. I've noticed that the CPU spikes everytime I do this and the temperature jacks up about 10 degrees C.
What I have done:Isolated the problem to the computer itself. It's not the speakers, I unplug them from the computer and it doesn't continue. As well as the fact that it only happens on 3d imagery. These are high end studio monitors(Behringer B2031A). I can't notice a sound actually coming from the computer itself. I've read some other forums and a lot of the responses suggests the problem was the PSU. I checked each of the components and I can't notice an odd sound coming from anything but the speakers. Checked to see if the CPU was spiking while it was happening and I noticed whenever 3d image was showing it jacked up to ~60% and the temp went up to about 50C(Cores). PC is currently overclocked to 3.7ghz so this is about right for the load. CPU idles at about 33C. Cores idle ~ 40C
Things ruled out:
- Nothing as of yet 4/23/2010 @ 9:16AM
Things tried
- Waiting
- Changing the sound card is a no go. Went from mobo sound to an audigy 2 pulled from a machine from my step father's shop.
- Unplugged the speakers, sound was gone.
Specs:
E8400 OC'd to 3.7ghz http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
Arctic Cooling fan. http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
4x1GB of Mushkin DDR800 http://www.newegg.com/Product/Product.aspx?Item=N82E16820146673
1TB Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
SAPPHIRE 1GB 4870 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
Gigabyte GA-EP35-DS3R http://www.newegg.com/Product/Product.aspx?Item=N82E16813128086
700W OCZ GameXStream http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
Any help would be appreciated!
Thanks
Things ruled out:
Things tried
- Waiting
Specs:
Thanks
