[SOLVED] SSD Slow Writing but normal reading speed
JoaoPauluu
11
Hello, I'm having a problem with my ssd, it is a bx500 240gb from crucial (dram-less), bought it ~ 10 months ago, did a speed test on the week of purchase, everything was fine, but tried to run a benchmark again recently an those are the results I got (using crystal disk mark. Already tested other software and got the same results): View: https://imgur.com/D29sQt4
I've already tried to reinstall drivers, update firmware, tried running linux mint live on a usb stick an then run the benchmark but still got the same results, I even tried Defragging the ssd to see if it would help but nothing changed. Everything is just like when I bought it, but for some reason the speed has halfed.
Trim is enabled, drive caching is also enabled, AHCI mode, on a sata 3 port and cable.
Any idea of what could be causing the issue? Is rma'ing the ssd the only option?
I've already tried to reinstall drivers, update firmware, tried running linux mint live on a usb stick an then run the benchmark but still got the same results, I even tried Defragging the ssd to see if it would help but nothing changed. Everything is just like when I bought it, but for some reason the speed...
Reseat the sata cable both ends...test
Try a different sata port on the mobo....test
Try a different sata cable....test
Do you have optimize setup in windows?
Is trim enabled in windows?
https://www.windowscentral.com/how-ensure-trim-enabled-windows-10-speed-ssd-performance
Hey man, just did everything that you said.
Tried a diferent sata port on the mobo, different sata cable, and different psu cable, nothing changed. 😕
I'm thinking about doing an ATA Secure erase next week and then reinstall windows
