So it turns out I have a little problem with this motherboard.
I recently bought an ASRock 970 EXTREME3 motherboard and attempted to install it in my system. However, when I had everything all set-up and switched on the power, the motherboard seemed to only turn on for a flash of a second then immediately off whereas my case fans as well as the CPU fan barely have enough time to barely perform 1/4 of a full rotation. After a few unsuccessful trial-and-errors, I tried the method whereas you disconnect everything but the big ol' ATX 24 pin cable, the front panel connectors, and the ATX12V1 cable for the CPU. I left the CPU's fan as well as a single case fan connected for testing purposes. I also uninstalled the board from my system and placed it on top of the anti-static bag it came in when I opened it's packaging.
I got the same result.
The next thing I did, however, completely put me in a blank. I disconnected the ATX12V1 cable (8-pin CPU power connector) and like magic, the CPU fan and case fan spun up and ran successfully.
Now unless that's completely blatant and I'm just plain ignorant on how motherboards operate, I'm pretty sure that ATX12V1 cable is important to the operation of the entire CPU and what I saw was just plain fans being powered with no actual activity from the CPU or motherboard. I actually connected my graphics card and monitor afterwards. The fans on it operated, monitor didn't turn on, and the green LED light under the power button was solid without flickering.
Here are my specs at minimal level testing:
XFX Pro 850W XXX Edition 80 Plus Silver Certified Power Supply
AMD Phenom II x4 840 CPU
ASRock 970 EXTREME3 Motherboard
All I need to know is what is causing the motherboard to fail immediately upon start-up, even with just the power supply connected to just the CPU and motherboard. Also, optionally, why it succeeds to power when the ATX12V1 cable is removed.
Additional Note: My old motherboard was a Biostar N68S3+. While is was removing the CPU heatsink to transfer the CPU and heatsink/fan to the 970, I heard a loud snap after releasing the heatsink handle. It seemed like nothing really happened and I proceeded to remove the CPU to put into the new motherboard.
It's also worth noting that the thermal paste looked kinda worn out and smeared, that is if it could really cause all this trouble.
