Stereo or full 5.1 with spdif output
ken
1,241
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have an Asus A8N motherboard and I want to connect up a set of Logitech
5.1 speakers via the spdif socket.
Does the SPdif support full 5.1 surround or just regular Stereo?
I only ask because when I connect it up, the logitech speaker control centre
says that it is stereo feed and gives no options for 5.1
Thanks very much for any help
Stereo, unless you have a DVD and set your DVD player to 'SP/DIF
Passthrough'
Sadly, you will only ever see that in NForce 2 motherboards that have
SoundStorm (eg. Asus A7N8X, Abit NF7-S)
> Passthrough'
Sad, but true :-(.
>> centre says that it is stereo feed and gives no options for 5.1
That's not quite true. Some new motherboards (all intel-chipset based,
afaik) can do this too (it's called "Dolby Digital Live"), for instance
the asus P5AD2 Premium. If I'm not mistaken, this is a 100% software
solution, but it probably won't take too many cpu cycles.
That other boards can't do it has no technical reasons, this is due to
licensing issues.
Roland
Real-time DD5.1 is back? Uber-sweet...though I'm an AMD-64 convert.
