Hi!
I'm running a Ryzen setup on an A320M mobo (to be specific, a Gigabyte A320M-S2H with 2 DIMM slots). Normally, I run 12GB of RAM with a 4GB stick (lets call this one stick A) and a 8GB stick.
So a while ago, I was just playing a game on my PC with no issues until the PC froze. I decided to hit the reset button, but then my PC wouldn't even hit the post screen. I tried to swap the arrangement of my two ram sticks and also tried to boot the PC with just one of each at a time on both slots to no avail. I then pulled out a single spare 4GB stick I had (lets call this one stick B because it's identical to the 4GB stick I ran normally), and on its own, the PC booted normally into Windows. I then tried it with Stick A, then it ended up booting normally as well. But when I tried it with my 8GB stick, it booted normally but Windows and my BIOS reported the 8GB stick as a 4GB only, so instead of having 12GB as I normally would, I only had 8.
Now the issue gets even stranger here.
I swapped out the 8GB stick again for Stick A, but unlike the first time I combo'd Stick B with Stick A, the PC wouldn't post at all. So then I switched it back to the Stick B + 8GB configuration, but for some odd reason, this configuration only works if Stick B is on the left and the 8GB stick is on the right. If I were to swap their positions, the PC would not post. But for some reason, the PC would happily boot normally with Stick B regardless of which DIMM slot I throw stick B in.
So my main question is this: Is it the motherboard's DIMM slots that are damaged? Or is it the original pair of RAM sticks that I ran with?
Just to repeat:
Stick A = My original 4GB RAM stick
Stick B = A spare 4GB RAM stick that is identical to Stick A.
Just to repeat:
