[SOLVED] substitute for B450 tomahawk / max version
epicevan
44
6
18,545
I've been looking at AMD motherboards around the $100-200 price range And most of the tech youtubers recommend the tomahawk. everyone seems to like it so much that it is now completely out of stock or at three times the Normal price on Amazon.
is there any motherboard that is at the same level of being critically acclaimed? and around the same price?
I'm basically a noob when it comes to this I've been looking at the ryzen 7 CPU
thanks for reading
i just bought a gigabyte aorus b450 pro wifi and it works well. no problems with a 3700x right out of the box :)
https://www.newegg.com/gigabyte-b450-aorus-pro-wifi/p/N82E16813145082
out of stock right now but amazon may have it or other place. stock is low everywhere so you're gonna run into this issue no matter what you pick!!
thanks, I checked it out and it's back in stock on the 16th for Amazon. I'll take it as a serious consideration. Lol, guess I'm <Mod Edit> out of luck besides that. Btw Do you know the reason that tomahawk is well-liked? is it just because it's B450?
