nrsaShubham
Commendable
Aug 3, 2017
70
plz suggest some Good Budget power supply for my old pc..(550-700watt) my budget is max 10k INR...but it is good if u get reliable PSU in less than 10k.....my old PSU is Corsair VS550....and i am facing some issues after 2 years so i want to change it with good one.i am frim India
my Rig
Ryzen 5 1600
Msi B350 motherboard
Cooler Master ML240 AIO RGB
G skill Tridentz 16gb
Gigabyte Aorus 1060 6gb
NZXT hue+..with 4 rgb strips
3 rgb fans Excluding AIO fans
1 tb WD blue
120 gb samsung evo ssd
tp link wireless internal adapter
From the onset of your alias/username, it seems like you're not located in USA. The reason I mention that is due to the fact that this site is based in USA and the majority of folks coming around here will suggest e-tailers in USA.
If you're located in an APAC region/country, then you should list the shops you have access to alongside their sites and include a budget for your PSU. Wattage wise, you're going to need a 550W unit but it should have a reliable build quality to it for the sake of ease of mind.
Reactions: nrsaShubham
