Question Suggestions on CPU upgrade to Ryzen 5 5600/5600X from current Ryzen 2600 ?
noro24
54
Hello Guys!
Recently, my GTX 1080 GPU died, so I bought an RTX 3070 Ti at a good deal. However, I'm not sure if my current Ryzen 5 2600 will bottleneck my new GPU.
I'm thinking to buy a Ryzen 5 5600/5600X without changing my current Asus ROG Strix B450F Gaming motherboard. I'm just asking you guys shall just buy CPU only or CPU and Motherboard, and if so which one, any pocket friendly suggestion?
My current specs
CPU - Ryzen 5 2600
GPU - Asus Tuf Gaming RTX 3070 Ti
RAM - 16GB (2 x 8) HyperX 3200Mhz
Storage 1 - 500GB Samsung SSD
Storage 2 - 1TB WB HDD
Display - Samsung 24inch Curved LED 144hz
PSU - Silverstone 750 watts Gold Plus
CPU Cooler - Deepcool LE500 240mm
Case - NZXT 500
Note : setup is used for normal gaming, such as Dota2, CSGO, COD, diablo, and also my current setup is in good condition.
Fairly reasonable to just get a CPU. But you could get something like the 5700X3D which would improve gaming performance quite a bit and not cost too much. Certainly the last CPU upgrade you will do for AM4, might as well make it as good as possible.
2x16GB memory kit as well maybe, but that would depend on if you are getting close to using the 16GB you've got.
Reactions: popeyetyty
so my current mobo would support ryzen 5700x3D? i heard there are some PCI 4.0 or PCI 4.1 combability issue, m not sure if naming them right or what
Yes, the CPU is supported by the motherboard. The same would be true of the 5600X/5700X. The Ryzen 5500 is limited to PCIe 3.0 itself, and is one of the reasons it is cheaper.
You are limited to PCIe 3.0, yes. But it is still an x16 slot which is equivalent to 8x PCIe 4.0. Plenty to run a 3070 Ti with only a minimal loss in performance.
Thanks, i will check it out Ryzen 7 5700x3D
Well, that depends. If you are replacing the motherboard, and CPU, only one step away from also replacing the memory. AM5/DDR5 may be the better option.
PCPartPicker Part List
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor ($191.41 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($34.90 @ Amazon)
Motherboard: Gigabyte B550 UD AC ATX AM4 Motherboard ($104.48 @ Amazon)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($51.99 @ Amazon)
Total: $382.78
Generated by PCPartPicker 2024-09-20 07:31 EDT-0400
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor ($182.14 @ Amazon)
Motherboard: Asus TUF GAMING B650-E WIFI ATX AM5 Motherboard ($149.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($99.99 @ Amazon)
Total: $432.12
Generated by PCPartPicker 2024-09-20 07:32 EDT-0400
well that's lots expenses right before my wedding, my fiancée will just kill me hahah.. i will buy CPU ryzen 7 5700X3D for now, then i will upgrade CPU and MOBO after couple of years!
Thanks for your help
Hello Guys!
So, my GTX 1080 recently gave out, and I ended up getting a great deal on an RTX 3080 12G. I’m a bit unsure though—do you think my current Ryzen 5 2600 will bottleneck the new GPU?
I can't upgrade the CPU right away since I have some bigger priorities for the next couple of months, but after that, I might upgrade it after 2 months, Would it be okay to use the Ryzen 5 2600 with the RTX 3080 until then?
I'm thinking to buy a Ryzen 5 5600/5600X without changing my current Asus ROG Strix B450F Gaming motherboard. shall just buy CPU only or CPU and Motherboard, and if so which one, any pocket-friendly suggestion for CPU?
My current specs
CPU - Ryzen 5 2600
GPU - Asus Tuf Gaming RTX 3080
Mobo - Asus ROG Strix B450F Gaming
Case - NZXT 500
You have a thread here on the same topic;
I would stick to the suggestion for a Ryzen 7 5700x3D. Ofc, you'd need to flash the BIOS to the latest version before dropping any Ryzen 5000 series processor onto the socket.
You might want to mention where you're located, what your preferred site for purchase is and your budget for your upgrade. Parts availability can and will change with region and as such can and will cause a flux in pricing.
Silverstone is the brand of the unit while 750W is the advertised wattage of the unit. What is the model of the unit? How old is the unit and what did it power throughout it's tenure?
A DDR4-3600MHz tight latency kit would go hand in hand with your processor upgrade, leaving your motherboard as is though you could still go for a B550 chipset board. At this point of the product's lifecycle, I'd stick to your current motherboard.
Case - NZXT 500
NZXT have a number of H500 cases int heir portfolio, which one do you have?
Case - NZXT 500
The PSU IS Silverstone Strider Gold S Series 750W 80 Plus Gold
and
The Case NZXT H500
Age of your PSU?
The Case NZXT H500
That case isn't exactly good in terms of airflow, might want to reconsider adding more heatware into that case. Regardless of which, you've forgotten to answer the other questions I had above. Please re-read all of the above post I'd made.
Age of your PSU?
The Case NZXT H500
Age of your PSU?
I've been using that PSU for the past 4 years, and haven't given me any problems yet.
well, it has 2 air extraction fans.
I'm from India and pricing for Ryzen 5 5600X INR 13.5K (USD 158) and Ryzen 7 5700x3D is INR 20 K (USD 240).
Since you need a gpu, go ahead and buy the 3080.
There is no such thing as "bottlenecking"
If, by that, you mean that upgrading a cpu or graphics card can
somehow lower your performance or FPS.
A better term might be limiting factor.
That is where adding more cpu or gpu becomes increasingly
less effective.
You WILL do better, the question is by how much.
Reactions: Lutfij
less effective.
I bought it at good deal, until i read it somewhere that it might not be good thought to pair Rtx 3080 with Ryzen 5 2600
Now i can wait 2 months and upgrade cpu !
with 3080 and 2600 you ''ll have in 1080p 45% bottleneck and in 2k 40%
Please stop spreading false made up bottleneck numbers. It is fake science and math to make you upgrade.
Some games( a couple) it might be up to 40% and others almost 10%.
He has a 144hz monitor.
so anything over 144fps will never get displayed. So it is a moot point. Unless he really likes playing at the lowest settings and resolution to see 300fps displayed in his on screen monitor.
Thank you, I played dota2, CsGo2 and Diablo 4
I hardly found any lagg though
I guess its good enough for couple of months then i might just upgrade
