I recently moved from Europe to the US and sent my desktop PC tower in a well padded parcel.
Before sending it off, my PC worked fine. Yesterday it arrived in the US and I checked for visible damage but there was none.
Nonetheless, the PC does not boot: the fans don't spin, the lights stay off, no noise. And obviously also no display output.
When I turn on the PSU's power switch, the motherboard briefly flashes white. When I switch off the PSU and on again after a short amount of time, the motherboard does not flash. Keeping the PSU off for longer and switching it on later, makes the motherboard flash white again.
The flashing LEDs are part of the RGB lighting of the motherboard. These LEDs used to be orange under normal operation. I don't think I ever messed with the RGB color setting.
But the regular power switch to boot the computer does absolutely nothing. Not even the status LEDs of the motherboard (for CPU, RAM, ect) show any activity.
I checked the PSU's manufacturer's website for a quick PSU test: short circuiting two pins from the cable going to the motherboard's 24pin connector does make the PSU's fan spin. This is supposed to indicate that the PSU should be OK.
How do continue I troubleshooting the problem? Is the PSU really OK?
Unfortunately, I don't have any spare parts here to test things with.
System Specs | |
Case | Fractal Design Define R6 |
PSU | Seasonic FOCUS Plus 650 Gold |
Motherboard | Gigabyte X470 AORUS GAMING 5 WIFI revision 1.0 |
CPU | AMD Ryzen 7 2700X |
RAM | 2x G-Skill Ripjaws 16GB DDR4-3200 |
GPU | MSI Radeon RX 580 ARMOR 8G |
NVMe M.2 SSD | Samsung EVO 970 256GB |
HDD | 2x Western Digital Gold 4TB |
