Last night my case's power LED started Blinking after shutdown. The internet suggests that this can often indicate a power supply issue, while my motherboard manufacture handbook says that the only case for the power LED blinking is s3 sleep state. I'll address each of these why I feel it can't be either of them below.
1) Power Supply Issue:
This one seems unlikely because there haven't been any other performance issues. I can still play games that pin my GPU and have no stutters, black screens, or crashes. There haven't been any indications that there is physical damage to the PSU either
2) System going to sleep state s3:
When I issue a shutdown order to windows the Power LED Blinks, which MOBO manual says means s3 sleep state. This is not the state my system is in because I cannot wake back up via a USB device. I also see a full post screen when I hit the power button again, which per my research so far, indicates that the system was not in s3 either.
3) Other Ideas seen already:
I saw some threads suggesting a broken/shorting Power Button/LED but the behavior described there is different enough I don't think it applies.
Are there other reasons a system will flash that power LED? If it is the PSU then how is it even detecting an issue if I am facing no issues with the system? The PSU is still under warranty but I don't want to start an RMA if there are other options.
System Specs:
Fractal Design Nano S Case
Ryzen 5 1600 (w/ aftermarket Cryorig Cooler)
EVGA 1070 Superclocked
ASRock Mini-ITX Motherboard - AB350 Gaming wifi
16 GB G-Skill RAM 3200Mhz
EVGA 500 BQ PSU
128 GB Kingston SSD
4TB Seagate HDD
System Specs:
EVGA 500 BQ PSU
128 GB Kingston SSD
4TB Seagate HDD
