Davil :
I was really more questioning how you regulate the temperature of the cold side of the peltier. Like does it have a constant draw regardless of how many volts you plug into it or do you have to adjust that manually? I didn't really follow what you were saying when you mentioned in the original post about using water to cool the hot side and burning your hand on the pump. That gave me the impression that the more you cool the hot side the hotter it will get and by comparison the cold side will get cooler.
By controlling the temperature of the hot side.
Yes it has a constant voltage, wattage, and amperage, draw unless you add some kind of a voltage regulator.
That was the radiator was too hot to hold your hand on, and the pump was an inside the reservoir model and burned out.
How could the hot side get hotter the more you cool it?
Wouldn't the hot side get cooler the more you cooled it?
The peltier itself is a very simple device that can actually do three actions depending on what you use it for, you can cool with it, you can heat with it, or you can get electricity from it.
When power is applied to the peltier one side gets hot and the opposite side gets cold, if you do not control the hot side heat and allow it to overheat past it's specs, the peltier will simply get too hot and burn out. Your Bad!
So somehow you have to control the peltiers hot side heat so it does not get to spec burn out, the hot side can be controlled numerous ways, many told me it flat out could not be done with an air cooler, but they were wrong!
The link below is the peltiers I am running.
http://www.frozencpu.com/products/2408/exp-01/245W_Potted_Peltier.html
These are the peltiers specs:
Maximum operating temp: 125 C
Imax: 26 Amps
Qmax: 243.5 Watts
Vmax: 15.4 Volts
Delta Tmax: >68 (C)
Size: 50mm X 50mm X 3.10mm
The maximum peltier operating temperature is 125 C that is basically the peltiers burn out point if it is allowed to reach that temperature, so you probably think that maybe 100 C would be a safe peltier operating range well away from it's burn out point, Right?
Well there's only one major problem with that thinking and that is 100 C is waters boiling point, so if you plan to cool the hot side of the peltier with water cooling, you will have to operate the peltier below 100 C, because you do not want 100 C even possibly building in your water cooling loop, because the system could build steam and explode as none of the components are designed for that kind of temperatures, pump, tubing, etc.
Is the veil of understanding beginning to lift for you, I would like to know before I spend the rest of the morning typing and you still don't understand?
So please help me, help your understanding?
Edit: I mentioned you could get electricity from the peltier, and if you artificially supply the hot and cold to the peltier, the electrical leads will read a voltage output.
For the Record: This system has been in operation now for 20 months.
