The idea with the single loop was to round off the issue Ryan seemed to refer to regarding the difficulty of controlling the temperatures on either side of the TEC. Ie, when the hot plate is cooled down too far the cold plate doesn't cool as much or something to that effect. In my head that looks like a sharp negative bell curve, which I imagine if you're also pumping varying degrees of hot through it from the CPU, the TEC is going to have to be all over the place trying to keep on top of it. SO! I figured, if you run the heat from the CPU and TEC together through the same radiator/air cooled heat sink, getting down to ambient as best as possible, (so not, no exact size of radiator, just the biggest I can afford, or a number in sequence) then the resultant liquid temperature leading back into the cold chamber will always be more or less the same temperature, whatever ambient is. Ergo, the TEC can be tuned to run at a more specific voltage, as heat from the CPU will be lost in the fluid of the hot chamber. As long as you can cool the hot chamber, the CPU temp doesn't matter.
Also, chamber volumes, not sure, there is likely some math can be applied here to give a figure, however, lets just ball park go with whatever Ryan used in his cold tank reservoir thing? Seemed to do the job
I'm not an expert hence why I am asking you guys, it seems like it would work in my head, provided the heat from the radiator can be dispersed. I have an old chimney hole in the wall I was going to put the radiator into. Big, big radiator. Lots of fans. Dedicated PSU all that jazz.
What else. Yes, right, pumps, in the wrong place. Should be between the CPU and hot tank. Ignore that. And... the shape of the hot and cold chambers is hypothetical too, the one I was debating building doesn't have a bulkhead but is instead two separate chambers in a sort of hourglass arrangement so there is no contact between the hot and cold sides, they also have internal insulation against the walls. But, that over complicates things and I don't have CAD access right now.
so that lot in mind, what do you think? Ryan is the expert it seems as he's actually built one of these devices which works, so, Ryan, do you think that your system could be enhanced using a single loop system such as this or is something I don't understand going to occur resulting in a resonant cascade scenario transporting me to Xen with no hope of return but to find the Gman?
