Ok, so right now I am running prime95(small fft), and here is a screenshot of the temps. I overclocked(first time ever) by upping the fsb to 1600, and that's all I did. What I do think is wierd is now cpuid is saying that I have Intel Extreme Q9450. Is that because it's overclocked? Cause I just have a regular Q9450. The temps are much closer now, within 7 or 8 degrees. Sound right to you guys under load like this?
Core 0 - 80 / Max 85
Core 1 - 77 / Max 81
Core 2 - 76 / Max 79
Core 3 - 84 / Max 87
These numbers are from using cpuid hardware monitor, now I got lower numbers mainly in the 70's using Realtemp 2.60. What do you guys think?
You can read more about this issue at these 2 links.
http://www.evga.com/forums/tm.asp?m=415987&mpage=1&key=񥣳
http://www.tomshardware.com/forum/252589-31-noob-temp-issues-help
Hope you guys can help. Thanks alot.
