[SOLVED] Throttlestop Help
Seeker21
42
Hello, I want to use throttlestop to undervolt my i5-8300h but I am worried that if I went to far that my system crashes and then when restarting it still applies the undervolts and I basically be stuck in a loop. I've ticked save voltages immediately in FIVR and made a task for throttlestop to start with windows in task scheduler so with these settings if I went too far will this crash loop occur?
Why do you want to undervolt it?
I've already undervolted the core to 170 and cache to 130 a year ago and I am thinking of pushing it more to see if I can get lower temps. With these undervolts and thermal repaste my cpu reaches 87° as max temp after few hours of gaming which I suppose is dangerous and is worrying me.
Why not attack the temp thing on its own, rather than crippling the performance.
Other than repasting and dust cleaning which I am not planning to do now this is the only thing which
I know of that will reduce temps. If it's safe then that will be perfect with me. I don't have a problem trying so many voltages and testing over long hours or days to see if the performance is impacted.
