Archived from groups: microsoft.public.windowsxp.games (
More info?)
That's fantastic news tomro, glad we could assist.
Cheers,
Jimmy.
"tomro" <tomro@discussions.microsoft.com> wrote in message news:E1317662-7E14-4C28-B359-51B07BE8D106@microsoft.com...
| I reinstalled the discs. The game works now. Thanks all for your assistance
| "Jimmy S." wrote:
| > Hi Tomro,
| > Here's some suggestions from EA which should help:
http://tinyurl.com/6v85v
| > Cheers, Windows XP MVP Shell / User
| > Jimmy S.
http://mvp.support.microsoft.com
| > Game FAQs:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
| > Visit my MSN Zone.com and Gaming Help Site:
http://mvps.org/nibblesnbits
| > MS Assisted Support:
http://support.microsoft.com/select/?target=assistance
| > My advice is donated "AS IS" without warranty; nor do I confer any rights.
| > _________________________________________________________
| > "tomro" <tomro@discussions.microsoft.com> wrote in message news:9B80F370-E071-48ED-B9AE-D73F690542FB@microsoft.com...
| > > Hi Jimmy S.
| > > Okay. Thanks. This worked! I was able to install the game, but when I click
| > > on the "Play" button on the opening screen I got the following error message.
| > > Game Crash
| > > "INI::load cannot open file 'Lang\***FATAL*** String Manager failed to
| > > initialized p\Language.ini"
| > > "Because of severity of this error the game will now exit."
| > > I checked the game's help section, but was unable to find anything specific
| > > to this message. What do I do now?
| > > tomro
| > > "Jimmy S." wrote:
| > >> Hi Tomro,
| > >> "tomro" <tomro@discussions.microsoft.com> wrote in message news:ABCA1C3B-060A-485A-BD73-1C10C2F2CFD3@microsoft.com...
| > >> > When attempting to install this game I receive the following messages:
| > >> > Dsetup.dll
| > >> > "Cannot get address of DirectXSetupGetVersion
| > >> > followed by:
| > >> > oops
| > >> > "m_DirectXSetupGetVersion is NULL"
| > >> > I've contacted the EA Games tech support and followed their instructions
| > >> > regarding background processes, tried copying discs and launching from my
| > >> > hard drive, even exchanged discs at their suggestion, and I still get the
| > >> > same message. I've run DXDIAG, which shows no problems. I have DirectX 9c and
| > >> > my computer surpasses all minimum requirements for the game. I have other EA
| > >> > Games and no problems.
| > >> > Any suggestions?
| > >> How to handle a DirectXSetupGetVersion Error:
| > >> Usually when I see this error, the computer had a previous
| > >> version of Windows installed, and XP was installed on top
| > >> of the older version of Windows instead of a clean install.
| > >> As a result the setup file which the game's installer looks for
| > >> doesn't exist in the location where it's searching.
| > >> There's a way to correct this issue without reinstalling XP:
| > >> Download and install the *Complete* DirectX 9.0c:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9226a611-62fe-4f61-aba1-914185249413&displaylang=en
| > >> *Antivirus / Firewalls can corrupt the download and installation,
| > >> it's highly recommended you disable them during this process.
| > >> After you install DirectX, reboot your computer and try
| > >> installing the game again. If you still get the same error:
| > >> 1. Search your hard drive for dsetup.dll
| > >> 2. Right click each instance of the file listed / select Properties
| > >> until you find one that is version # 4.9.0.902 or 4.09.00.0902
| > >> Right click and Copy that file, we're going to paste it in Step 3.
| > >> 3. Go to c:\Windows\system32, rename dsetup.dll to dsetup.old if
| > >> it exists, and then Paste the file we copied in step two into the folder.
| > >> 4. Reboot, and install the game again. If you still get the error
| > >> double-check that the file was copies properly in step 3.
| > >> Well, it's a bit of work, but I hope it works out for you. Best of luck!
| > >> Shell / User
| > >> Jimmy S.
| > >> Game FAQs:
| > >> Visit my Zone.com / Gaming Helpsite:
http://nibblesnbits.tk or Call / Contact
| > >> MS Support at:
http://support.microsoft.com/default.aspx?scid=sz;en-us;top
