I have no idea if this even possible, I may completely wasting my time but I am trying to connect a CRT Monitor to my modern PC for some retro emulation.
This is my current build:
Asrock B450m pro4 AM4 Motherboard
Ryzen 5 3600x CPU
RTX 3060 12gb GPU
Corsair CX-M 650W
16GB RAM
The CRT monitor I have only has a VGA connection and obviously the RTX 3060 has no analog out to connect to the monitor. My first thought was just to use a DP to VGA converter but I realized that would add a decent amount of input delay as it's going through a DAC. My next idea was to put an older graphics card that has a DVI-I connection into my current system. I found a GTX 750 on facebook marketplace for cheap that has a DVI-I output. Would it be possible to have both of these GPUs in my system at the same time? And if I can have both of them in at the same time can I tell Windows to only use the 750 on specific applications like emulators? After doing some research it seems like my main limitation is the amount of PCIe lanes that my mobo and CPU can support. From what I understand (which is not a lot) I would need to upgrade my motherboard to a board with two PCIe 4 x16 lanes as my current only has one PCIe 3 x16 lane.
Is what I'm trying to do even possible or am I better off just getting an old laptop with an analog display connection? Any help or new ideas would be greatly appreciated.
Ryzen 5 3600x CPU
RTX 3060 12gb GPU
Corsair CX-M 650W
16GB RAM
