Question Turning wifi to wired connection
stan10
43
I have a wifi device but I would prefer using it as a wired device. I would like to know if it is possible to stop the wifi device from giving out wireless connection signal so that I can instead use a usb wire to connect to my pc and share internet directly to my pc from the device.
disable the wireless device on the pc. or just plug in the Ethernet cable
what exactly is this wifi device?
it's one of those small mifi devices, I want to know if I can disable the wireless connection, as it is now, whenever I put it on, it shows that a wifi connection is available, I want to know if it is possible to disable the wireless connection signal that the wifi device gives out.
