[SOLVED] TV or Monitor : for bedroom
I want a screen that is at least 1080p and 32" (no bigger or smaller). And all the TVs near me are only HD, 1366x768. So, I'm considering a monitor instead that might even be 4k. Although I'm fine with 1080p. I want it to connect a raspberryPi for movies and wife's apple thingy.
Issue is sound. With a tv I'd have at least ok sound, but monitors require speakers. What kind of speakers would work for a wall hanging monitor? Also, switching inputs for devices...would it affect speakers too?
Any advice would be appreciated.
For what you want I expect a TV will be more convenient. If you can tolerate TV speakers you have them, then you have a remote to change devices or adjust sound. Also it will have other smart features.
The big question is how much do you want to spend? For me the money is no object option would be the LG CX 48inch if you have room.
32" is my limit. I don't want a massive tv and it'll fit perfect at that size. Just shocked that 32" tvs rarely are 4k, and hard to even find something as "small" as a 32. But I may buy a Samsung tv for much more than I wanted to spend. It would be $600usd, and hoped for like $200.
I brought this up to see if monitor could work, but tv seems easier for simplicity.
