Two network cards. Help!
luser
26
Hi all!
I'm trying to setup my 2 comps according to this (both running XP);
One computer with 2 network cards (nic), with one of it's nics connected to my ADSL, and the other nic for communication with my other comp through a cross over tp cable, which of course also got a nic. All i want to do with the comp that has only one nic, is to get hold of the resources i have shared on it.
Is this possible? The comp with the 2 nics is the only one that needs the connection to the ADSL. I have read a tutorial for this solution before, but i have forgot where...
I know it's easy to set this up with linux, but that's not what i want...
Computer1_NIC1 <--------> ADSL
Computer1_NIC2 <--------> Computer2_NIC1
//With kind regards, Luser
easy to do, assign each of the local systems and ip, such as 192.168.1.1 and 192.168.1.2, tho not neceserry, I'd setup file sharing to enseure the connection was working between the 2 pc's, once they are seing each other, run ics.
If they squeeze olives to get olive oil, how do they get baby oil?
