[SOLVED] "Ultra USB Power" ports causing fans to spin after shutdown ?
4
Hi, bit of a weird one.
Just got a new PC with the Asrock X870 Riptide WiFi motherboard.
I use several external harddrives that are connected to a powered USB hub. The issue is as follows:
  • if I connect the powered USB hub to one of the 2 ports that are labelled as "Ultra USB Power" and then turn off my PC, within a second of turning off all the case fans start spinning again, at max speed. All the other RGB and fans (e.g. CPU or GPU fans) are off, it's just the case fans that start spinning.
  • if I connect the powered USB hub to a different usb port, one that is NOT labelled "Ultra USB Power", everything is as expected - I turn the PC off and no fans are spinning, the PC is "truly" off.
I'm sure it's related to the "Ultra USB Power" port because:
  • if the issue is happening (i.e. powered USB hub is connected to the "Ultra USB Power" port, PC is off, fans are spinning) and I then unplug the powered USB hub, the fans stop spinning. If a moment later I plug the powered USB hub in again to the "Ultra USB Power" port, the fans start to spin again (while the computer is off the whole time).
  • turning the PSU off, and even unplugging the power cable, doesn't stop the fans from spinning if the powered USB hub is plugged in to the "Ultra USB Power" port
What is going on? Is there a setting I can turn on/off to disable this behaviour?
The powered USB hub seems to be a factor in this, because when connecting a hard drive directly, or my KVM switch, or other devices to the "Ultra USB Power" ports, everything is normal. The hub in question is Powered USB Hub Acasis 7 Ports 36W USB 3.0 Data Hub with Individual On/Off Switches 12V/2A if that matters
The case fans are all connected to the ARGB/PWM hub except for one that's connected directly to the motherboard.
I have tried updating and resetting the BIOS, didn't help.
You might find this interesting:
https://forums.tomshardware.com/threads/usb-ports-on-motherboards.3716281/
I think you've already found a solution. Don't connect the powered hub to the Ultra USB Power ports.
You'd need a "diode OR" circuit to prevent +5V from the external hub's PSU feeding back into the PC via the Ultra USB ports. With diodes placed in strategic locations, the external hub's +5V supply would be blocked by a reverse biassed diode.
https://en.wikipedia.org/wiki/Diode-or_circuit
It's not the sort of modification which I'd recommend, even using MOSFETS or Schottky diodes with low forward drop voltages, but it's commonly used in electronics where you don't want this sort of power supply feedback.
Are they small 2.5" portable hard disks, or larger 3.5" desktop hard disks. or perhaps they're SSDs? I find that a single 2.5" hard disk runs quite happily from a USB2 port with its built-in 500mA current limit. I run my 3.5" desktop hard disks off their own individual +12V supplies.
You should be able to run two 2.5" hard disks off a standard USB3 port with a 900mA current limit via a passive (unpowered) hub. If you have more than two 2.5" hard disks, you could try running them from a passive hub connected to an Ultra USB Power port. Disconnect the external PSU from the hub and see what happens.
Thanks for the reply!
Indeed, after posting this thread I discovered more of these threads so at least I'm glad I'm not alone with this issue.
That "diode OR" circuit thing is definitely overkill for my purpose.
As for not connecting the USB hub to the Ultra USB Power ports, the thing is that the Ultra USB Power ports provide better speeds compared to the other USB-A ports. I noticed this when doing my regular file transfers. You can see the speeds below:
I tried disconnecting the power supply from the powered USB hub, thinking that maybe one of these "Ultra USB Power" ports could power it but nope.
I read about data only USB cables but couldn't find any modern ones, only USB 2.0 ones.
In the end, I have ordered a USB-A (female) to USB-C (male) adapter (specifically Type C to USB Adapter USB-C 3.1 OTG A Female Data Connector Converter 10Gbps) I'll post back whether this solves the problem or not.
I tend to run my faster portable SSDs from the USB-C ports, either front or back. I don't have any hard disks that run faster than 250MB/s, so USB3-A is fine. I don't have any Ultra USB ports so I can't check things out.
Are your external drives connected to the hub SSDs or spinning hard disks. If the latter, are they 2.5 or 3.5"?
I have 8 2.5" HDDs, four are main and the other 4 are their backups/mirrors. So most of the traffic is copying data between them.
I know about the 3-2-1 backup rule but for the data in question my current approach is what I'm happy with.
I have 8 2.5" HDDs
These days, I'm happier with hard disks physically buried deep inside my computers. Less chance of wires becoming disconnected.
I have a dozen 3.5" external USB3 desktop drives (WD and Seagate 2TB to 8TB) gathering dust in a cupboard. Being 3.5" and not 2.5", they run extremely hot and are probably all Shingle Magnetic Recording and hence slow. These days I buy only PMR/CMR drives.
I used to worry about knocking the USB drives over and disconnecting the cables or causing damage with head crashes. For long backups, I aimed a desk fan over the USB caddies to keep the drives below +50C.
I'm sure your 2.5" setup runs much cooler. Just guard against Ransomware.:)
Welp, looks like it's those "fancy" ports ("Ultra USB power") that are causing the issue?
The USB-A (female) to USB-C (male) adapter arrived and when attaching the powered USB hub via this adapter to the USB 4.0 port on the motherboard, the fans no longer spin up when the computer is off, meaning that backfeeding is no longer happening, or is somehow getting blocked.
In retrospect I guess I should've gone with a different motherboard but you can't predict everything.
Hi everyone, I can't believe that after all this time I finally found someone with a similar issue.
Did changing the port ultimately work, and do the fans turn off after shutting down the computer from within Windows?
I need to try the same thing—I was this close to buying a new motherboard.
