✅ASUS ROG STRIX B550-F GAMING (WIFI)
✅RYZEN 9 5900X
✅COOLER MASTER MASTERAIR MA610P RGB
✅2X16 3000 MHZ CORSAIR VENGEANCE RGB PRO
✅MSI GTX 1080TI 11GB GAMING X
✅SSD KINGSTON UV400/V300/Samsung 860 EVO | WD BLACK 5TB | WD BLUE 1TB
✅AEROCOOL KCAS 700WFULL RANGE
✅CORSAIR GAMER 4000D AIRFLOW BLACK
I did the UV with Rayzen Master because if something goes wrong, the BIOS will restart with default config and boot without problems. Also i only want to activate the UV when playing games.
I got TEMP high as a peaks of 80 - 85 ºC while playing some games.
So i lowered the frequency at 4400Mhz and the Voltage to 1.2 and now i get max temps at 65.
Now my questions are:
1- I should try to low the Voltage more or it's fine for that frequency?
2- Why HWiNFO64 shows the frequencies at 4400 Mhz all the time when it's not the reality, because if i watch in RM i can see the frequency isn't at the max and even some cores sleep.
Thx in advance.
PD: I don't use Clock Tuner because it doesn't works and not shows cores speed readings.
EDIT:
The HWiNFO64 doubt have been resolved. (I just need to expand the "Core Effective Clocks" arrow)
I still would like to hear an opinion about the Voltage and Mhz.
✅RYZEN 9 5900X
Thx in advance.
EDIT:
