Approximate Purchase Date: No rush but see more details below
Budget Range: Roughly £1k
System Usage from Most to Least Important: Writing, Surfing the net, Basic Video Editing (Camtasia) and eventually some casual gaming
Are you buying a monitor: Yes
Parts to Upgrade: Probably everything eventually...
Do you need to buy OS: No
Preferred Website(s) for Parts: Anything UK based at a reasonable price
Parts Preferences: I'd like to stick with Intel and NVidia. I've had better experiences with these.
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: Currently 1920x1080. Looking to upgrade this 2K+
Additional Comments: The main goal is to increase my screen real estate so I can view more at once on the monitor. For more info, please see below.
And Most Importantly, Why Are You Upgrading:
My current build:
I'd like to upgrade my current system for everyday work use/video editing. The video editing is nothing major, just screen recordings via Camtasia. I have a 27" 5K iMac with FCPX for the majority of my video editing.
The main goal is to increase my screen real estate so I can view more at once on the monitor. 1080p on a 22" just isn't enough. I'm thinking 1440p @ 27" and 144Hz. Probably an IPS panel because of their superior viewing angles although backlight bleeding tends to worry me?? I'm considering G-Sync too. However, I don't know enough about monitors for this to be a final decision.
I've also been considering the Nvidia GeForce RTX 2060 as great value for money?
I should also add that I do not want to add a 2nd monitor to the mix.
Eventually, I'd like my setup to be good enough for casual gaming at a half decent performance too.
I'm thinking the best move is to buy a new monitor and graphics card. That graphics card can then be used in my system when I upgrade the remaining hardware.
I should state that I'm in no rush but the sooner I can increase my screen real estate, the better.
The budget for now is roughly £1k (for the monitor and GPU...IF that's the smart thing to do).
Thank you for all your help.
Overclocking: Maybe
My current build:
- ASRock S1155 Z68 Pro3-M DDR3 mATX
- Intel Core i5 2500K Unlocked, S1155 @ 3.30 GHz
- 16GB Corsair Vengeance DDR3 1600MHz DIMM 240-pin CL9 LP
- PNY NVidia GeForce GTX 560 Ti 850MHz 1GB PCI-Express
- ThermalTake TR2 700W PSU TR-700P 80plus BR
- 22" ViewSonic VX2239WM 2ms Monitor
