Hello. I've recently changed my Palit GeForce GTX 1070 Ti JetStream GPU (which was perfectly fine, i thought it was broken since it was a 2nd hand deal) with an ASUS RTX 2060 RoG OC. So basically, when I changed the fan speed of the Palit GTX 1070 Ti, the PC would make an electrical noise, and then it would shut down. As it may sound like, this is actually not coil whine, nor the GPU's fault, because THE EXACT SAME THING HAPPENED with the BRAND NEW Asus ROG STRIX RTX 2060!!!!!! And no, it's not the power supply, I've had 2 thus far (seasonic 750w platinum and coolermaster V1000 gold) which are perfectly fine. Damn, I've spent 130 euros on a PSU i thought was broken! I STRUGGLED WITH THIS PIECE OF crap FOR 3 MONTHS STRAIGHT, JUST TO WASTE 500 EUROS ON A PROBLEM THAT STILL EXISTS! Please, I need urgent help. (HD 7700) had no problems at all, because it required a 6 pin power connector.
On the other hand, BOTH of these GPU's have a 6+8 pin POWER connector
I'm speculating that the 8 pin is not installed as it should be
Also, the WRAITH PRISM cooler is V E R Y loud, could it have something to do with this?
