I would like to buy a USB hub and extension cables, so that I can have USB connections more conveniently available.
My PC is not right next to where I sit.
I would need extensions of about 10 meters (about 32 feet).
It's not a big problem if I want to use USB 2.0, there is a wide selection of both hubs and active extensions available, but seeing as USB 3.0 will soon be the standard I would like to go for a "future-proof" solution.
Buffalo has a 4-port hub, the BSH4A03U3, but the article says it's only available in Japan. I live in Norway and have been unable to find it in any US or European shops.
I could possibly obtain one, I know someone who has connections to Japan (although it would be more convenient if I could obtain it without asking him).
A bigger problem, however, is finding USB 3.0 extensions that goes as far as 10m/32ft (I know there probably wouldn't be one cable that goes that far anyway, would probably have to be two of 5m/15-16ft).
Anyone knows about something like this?
Thank you.
Thank you.
