hatahf
7
Hello,
hi
I have a usb-lan DAVICOM Semiconductor, Inc. that work good
when I connect it with a pc it say that cable unpluged but cable is ok and pc connected to internet well.
sorry because of my english(i'm from Iran)
thank you
Go to your network connections. You likely have multiple network connections setup. You can disable the one that says it's unplugged, and it will get rid of that notification. Your lan connection should still be enabled, and you should still be able to access the internet.
hatahf
7
my lap top have no lan divice
usb lan connect well to internet bbut when I want to connect it to my pc it not work
hatahf
7
yes it works alone.
before I connected two pc together and know some info about this, but I don't know what is the problem.
hatahf
7
sorry because of delay...
some friends said that cross cable must used for connect two device.
I'm sure this is the answer but I did not try yet
