Hi
djgioxofficial
If you wanted to overclock the CPU – you’d need a different version.
What do you want to use your PC for? Need to know that to really get a sense of the fit with the parts you’ve chosen?
If it’s gaming – then you might want to get a high refresh rate monitor eg 144hz or higher? Especially if you like twitch shooters.
BTW you know you can get super cheap VGA adapters right? Or at least back in the day you could?
Could always just use the old GPU to keep it simple for now? Hopefully someone else can tell you if the APU is better or worse than the GPU?
Are you sure either will do the resolution and refresh rates you want? If you’re not fussed about gaming – you could always buy a cheap low level second hand GPU if not. Get a better gaming one later if you want.
That would let you use the APU easily…. And are you sure there aren’t any other HDMI, Display Port etc on the back I/O Plate of the motherboard/PC that you could use as an output from the APU to a monitor?
The other simple solution is to get a second hand monitor for cheap. Loads on the market and quite often perfectly fine as a temporary monitor. Probably guarantee you could get away better screen than your old one for sure – even for like $10-50 if your lucky!
Here’s what your mobo says about m.2 types/speeds/slots…. Are you ok with only PCIE 3… ?
Storage
3rd/2nd/1st Gen AMD Ryzen™ Processors :
1 x M.2_1 socket 3, with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)*
1 x M.2_2 socket 3, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)*
2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2_2 socket 3, with M Key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 X2 mode)
Total supports 2 x M.2 slot(s) and 6 x SATA 6Gb/s ports
2 x SATA 3Gb/s port(s),
2 x SATA 6Gb/s port(s)
2 x SATA 6Gb/s port(s),
AMD B450 chipset :
AMD Athlon™ with Radeon™ Vega Graphics Processors :
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
https://rog.asus.com/motherboards/rog-strix/rog-strix-b450-f-gaming-ii-model/spec
Good luck
