Hello, I need to find a way to get 5G wifi at home, currently I have a device that acts as both router and satellite TV, therefore I cannot really replace it in just a new router, this device only support 2.4G wifi.
I think there are 2 solution for this, the first would be using a wifi repeater that can receive an ethernet connection and broadcast 5G, the only issue with that is it seems that a gigabit ethernet port increases the price by quite a lot, and I can't really tell if it's really gigabit or just false advertising.
I've seen the following for example(I cannot order from amazon, so my only option is pretty much aliexpress):
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
It looks decent, and it's advertised as gigabit ethernet, but can't really tell...
I've also seen the following item:
https://www.aliexpress.com/item/330...earchweb0_0,searchweb201602_,searchweb201603_
I can't really figure whether it's a router, a repeater, or maybe both? As it seems like it only has ethernet connections and not ADSL or anything else(unless it works differently nowadays 😛)
I need the 5G for some device I'm using, for my PC I'm using an ethernet cable directly. Would love to get some assistance with that.
Thanks!![Smile :) :)](/data/assets/smilies/smile.gif)
Thanks!
