G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
First I'll explain what happened. I didn't install anything new, or
change anything. I turned off my computer, left it for a week, came
back, and it didn't turn on anymore. The thing is that I didn't touch
it for the whole week. It was untouched and off for a week, and then
doesn't work all the sudden.
Anyway, I opened it up, and pushed the power button. When I do this,
all the fans on the computer move for a second, and the power light
blinks on, then everything just stops and the computer doesn't work.
At first, everyone I knew thought it was the power supply. We took a
cord from my friend's power supply and plugged it into my fan, and
the fan worked. That seemed to give it away. So, thinking that since
I upgraded my system about a month past, perhaps my power supply was
strained because it was low voltage (230watts?), so I just got a new
400 watt one. I plugged it in and all, same exact problem as before.
The three things that don't make sense is:
1) It hadn't been touched for a week, so I couldn't have fried
anything right?
2) I plugged my fan into a friend's power supply and it worked dandy.
3) The fans work for a SECOND then turn off. That means power is
traveling....it's just not consistent or something.
I'm stumped, so if anyone can offer any advice, I'd be grateful.
anything right?
