Video problems playing TV over DC10plus card
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
All I want to do is be able to watch video comin in over my AV
connection on my PInnacle DC10+ card on my monitor at a decent size.
The studio 8 software that came with the card will only show the video
in a tiny preview window unless I record it to my harddrive and then
play that which seems a little pointless.
I have found a couple of free apps that will supposedly let me see
watch the video stream fullcrteen or at some other resolutions
windowed on my desktop.
The video displays fine in a window at resolutions up to about 320x240
but as soon as I try it full screen or at 640x480 or bigger I see
0.5secs of motion the it freezes for 0.5secs then moves, then freezes
ad infinitum.
I am assuming that as it displays the video fine at small resolution
it is being decoded ok so the issue must be with the display. I have a
Leadtek branded GeForce 2 Ultra with the latest drivers.
Any one have any ideas as to what might be causing the problem?
Thanks in Advance.
Graham.
"Graham Simms" <graham@muscat.com> wrote in message
news:26baf8c0.0407020601.2b739e8b@posting.google.com...
> ad infinitum.
> Thanks in Advance.
> Graham.
Try AMcap. http://noeld.com/programs.asp?cat=video
I sometimes have to start my normal capture program, (Movie Mill)
to initialize the capture card, then exit that and start AMcap. It works
great if you want to have a "borderless" display box that you can make
any size, have always on top-or not (F12), go full screen and back, and
take stills.
[Forgot whose post clued me into this little gem.]
Luck;
Ken
Latest posts
