Im Working on my First water cooling setup adn am trying to avoid using two Pumps. I have tried finding some information of Cooling loops and pretty much find res>pump>block>rad, but as you can see im looking to Cover two rad's one single and one Dual. Blocks will be NB, Voltage reg, CPU, GPU the SB will be Covered by a small fan as well as Ram. MB that will be in use is the EVGA 790i Ultra GFX card currently will be a 8800GTX until i flip the coin for GTX280 or 4870x2. I have put together that amazing piece of art that i would like to share with everyone.
Slam it, Fix it, tel it to be bad.
Im looking for any suggestions that can help me out further before i make final purchases.
The Case is a CM stacker 830. The Single Rad will be placed in the back on the 120mm fan mount(blowing air out) and the Dual Rad will be placed at the bottom on the case(blowing Air out). i plan on having the Single 120mm fan up top(blowing out) and possibly 2x120mm fans in the front of the case pulling air in. To help direct some of the air i will be removing the Mesh from the sides of the case and replacing it with Plexiglas.
Thanks again for lending a hand or pointing me in the right direction.
![Watercool.jpg](/proxy.php?image=http%3A%2F%2Fi185.photobucket.com%2Falbums%2Fx199%2Ffreeldrl%2FWatercool.jpg&hash=fdf9f2df362e8816967bf8ee04b82845)
