I'm quite new to water cooling and recently ordered a swiftech H20-320 Edge, and a swiftech MCW-80 to cool the GPU. I was planning to run SLI at some point and was going to add in a second MCW-80 as well as a double 120 rad. This will all be mounted in a Corsair 800d.
Now the triple 120 rad was going to be mounted in the most logical place in the case...the top. With the pump / reservoir integrated into the rad, this leaves me to cut a hole in the case. I can do that, I'm just not particularly fond of doing so...particularly if I do a push / pull configuration I would think there'd be a significant gap between the hole in the case and the actual fill port on the res.
Sorry for the tl;dr lead in to my question, but I was looking at some rad prices for double 120 rads, and since the MCR-220 rad is sold out on jabtech, I began considering the MCR-220-QP which also has a built in reservoir. Would there be a problem simply using this one, with the second reservoir, and mounting it in a more ideal location to fill the loop instead? (It's a three dollar difference between the MCR-220 and the MCR-220-QP...so negligible.)
