[SOLVED] Webcam Mic obly activates with a loud noise then quits after few seconds...
Jan 14, 2021
Hi
I got a plug and play Trust webcam (driverless) with integrated microphone.
Problem is that video works Ok but mic only seems to activate with a loud noise and then cuts out after a few seconds. I ran trough all settings etc that were suggested by Trust and on Windows forums but still no joy....
Any ideas?
Thanks
Try another known working webcam/mic on your computer.
Try the Trust webcam on another known working computer.
Determine if the problem follows the webcam or stays with the current host computer.
If the problem follows the Trust webcam then it is likely defective and should be returned.
