[SOLVED] Weird sound from my PC
Nov 24, 2019
8
Hi guys,
I built my pc over a month ago now, and everything has been all good up until about a week ago i'd say. I started noticing a rattling/grinding type sound coming from my PC. I suspect it is one of the fans, but I for the life of me can't tell which component it could be.
Have any of you experienced this, if so, what did you do to solve this type of issue?
Thnaks for the help :)
Nov 24, 2019
8
for the case fans you could unplug them and see if sound is up also if you have a gpu could you remove it from board and use onvoard for sound test .
Ok I've done this, thank you so much for the tip, as I've figured out that the middle fan at the front of my case is the culprit.
Now I just need to figure out how to get to the fan lol, but thanks again though :)
