What do I need for these parts?
farestar
15
So I've hit a bit of a speed bump in the creation of my new computer, some of the parts I've ordered (Now received) didn't come with any cables? I'm not to sure if they were supposed to, but it sure seems like it, honestly I'm a bit confused.
The HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Hard+Drives-_-Western+Digital-_-22136769
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148529&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Solid+State+Disk-_-Crucial-_-20148529
DVD drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136247&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=18n7cad70na7h
Have no cables, which I'm fine with. But what cables do I need? And which ones go to which??
Thanks for any help :) it's very much appreciated
farestar
15
Well I suppose, but isn't there supposed to be cables included that go from the device itself to the Motherboard as well? I thought some of those were included, or were supposed to be. I already got my PSU and case as well though. My case has nothing but screws and cords for what all seem to go to the usb, led and fans etc... The PSU only really has the power cables for the SATA, I just looked.
something is not right then you should of had most the cords come with the PSU all those plug into different things such as hard drive ssd mobo,video card,fans elect
farestar
15
Well yes, the PSU has ALL the cables for power (IE from the PSU into the Mobo, into everything else etc...) but the items; HDD, SSD and DVD drive, don't have any of the cables that should be going into the motherboard to actually use them.
farestar
15
I'm pretty sure I did for the parts mentioned, that's basically why I need to know which cables I need for the parts I linked to... Probably the cables going into the mobo, not the cables going into the parts themselves
farestar
15
No, i understand what you're saying (I really like the video btw, I'll probably be watching it while I do my first build :) ) the problem is the fact that I don't know which cables I'll have to order, like the guy said, each of the drives should come with their own cables that you can use to plug them into the motherboard for data use (The psu I have came with everything I should need for the power connections, I THINK :p ). My Motherboard DID include 2 SATA 3 6.0gb cables (So I should be good to go with the HDD and SSD) the only issue now that I can think of, is the Optical drive :p it has no cables, but it says it uses SATA, should I just order a standard SATA data cable??
