[SOLVED] what is going to be the best microphone for under £150 ?
OrdJk
231
6
4,595
I have the audio technica at2020 in mind but it needs 48 volts and that would make it outside the budget
I also have looked at the rode nt mini mic.
Any suggestions (and why) would be helpful
I imagine most usb mics will suit the job well. A cardioid pickup pattern and minimal proximity effect is what you're after. That way you can turn the gain down and get right up on the mic without it becoming to bassy.
Reactions: OrdJk
