So I recently just replaced my case and my ram along with it, my original case fans had a splitter that made the front 3 fans connect by using only one 4 pin connector. So when I got the new case, (Corsair 465x) the fans were better but I ran out of space on the motherboard for fans, ( I had another that was in my other case, so I bought a connector to power my fans from a sata cable (here). So a few days after the controller is installed my status LEDs started to come on for my DRAM, VGA and CPU when I turn on the computer but come off after a second. Since that started happening I can tell something is wrong with my computer, after about 5 hours of school work, one of the Status lights came on and I reset the computer and it went off, and after about 2 hours of playing rocket league my system completely reset itself. Which has never happened even putting over 65 days of game time into fortnite with my old case.
When I first got the computer, I was told the power supply was sufficient but will need to be upgraded, I just want to make sure that its that and nothing else.
Build
-AMD Ryzen 5 2600 (stock cooler I just ordered the a500 but I'm afraid to install it with these issues.)
-Nvidia Geforce GTX 1070ti ACX
-B450 Aorus Pro Wifi Rev 1.0
-Corsair Vengeance 16x2 2666
-EVGA 500W
-Corsair 465x
Build
-EVGA 500W
-Corsair 465x
