My laptop is Acer Aspire E15 E5-573G-53N3 (intel core-i5-5200U). Is it possible to use a 144Hz external monitor with it?
It depends if the port is controlled by the iGPU or the dGPU. The last three laptops I've used with hybrid graphics had the HDMI port connected to the iGPU. If it had a DP port, it was connected to the dGPU.
You can find out by plugging in a monitor to the port and opening Settings, then go to System -> Display -> Advanced display settings. It will tell you which GPU it's plugged into.
Being a mxm module card, its power draw is rated at 33 W maximum. This device has no display connectivity, as it is not designed to have monitors connected to it. Rather it is intended for use in laptop/notebooks and will use the output of the host mobile device. GeForce 940M is connected to the rest of the system using a PCI-Express 3.0 x8 interface.
- Max Resolution (HDMI)‡2560X1600@60Hz
- Max Resolution (DP)‡3840x2160@60Hz
I'm not sure about the external refresh rate it will actually support, I've had mixed success on laptops. However both the CPU and 940M will only run very old games at anything like that refresh rate.My laptop is Acer Aspire E15 E5-573G-53N3 (intel core-i5-5200U). Is it possible to use a 144Hz external monitor with it?
