PL1 is idle whereas PL2 is what it can max do under load.
yes, I see conversation moved on. I just thought i simplify difference.
no software monitor is perfect way to get accurate power measurements. hardware more accurate. I noticed that looking for a way to figure out your question.
one fix is to run the power troubleshooter
settings/update & security/troubleshoot/additional troubelshooters/Power (it is in bottom section)
Method 2: Reset Power Plan.
Step 1: Click on the
Start Menu and search for
Command Prompt.
Step 2:
Right Click on the
Command Prompt and click on
Run As Administrator.
Step 3: Now, type the following command and hit Enter.
- powercfg –restoredefaultschemes
Step 4: Once you have entered the above command, exit from Command Prompt > Restart the PC once for the changes to take effect and check for the issue.
https://answers.microsoft.com/en-us...d/5bcfef49-ea7b-4f47-bfe0-1f87e9642f45?auth=1
https://www.dell.com/support/conten...pport-knowledgebase/battery-and-power/Battery
